speed up torrents
mdagenais13
1. This isn't a feature request, so shouldn't be posted in this section.
2. You should read up on how torrents work, it's not the software that determines the speed, it's who you connect to. Once you've found the best settings for your connection speed you will get the best possible speed from the available peers.
Guest
