Diamond Posted November 13, 2011 Share Posted November 13, 2011 Hello, In the latest version 1.30, if the toolbar is enabled it interferes with keyboard navigation using Tab and Shift+Tab in the main window. To demonstrate, make sure that the toolbar is enabled and then hit the tab key a couple of times. The keyboard focus will be placed into a control which prevents further navigation using Tab and ShiftTab. I believe what is happening is that the toolbar panel is being given keyboard focus which is not typical behavior and was probably not intended. Thanks and regards. Link to comment Share on other sites More sharing options...
Diamond Posted December 6, 2011 Author Share Posted December 6, 2011 This problem still occurs in the new beta version. Link to comment Share on other sites More sharing options...
