Apocalypse2012 Posted January 30, 2012 Share Posted January 30, 2012 It would be real nice if you let me keep my settings after an update I do not want preview but you always put that back after update , it's real anoying to set it back to the way I want it to be, tha includes the "autostart on windows startup" Link to comment Share on other sites More sharing options...
Apocalypse2012 Posted January 30, 2012 Author Share Posted January 30, 2012 oops, not for forum. settings in client. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted January 30, 2012 Share Posted January 30, 2012 Updating bitcomet won't change any of your preferences. Link to comment Share on other sites More sharing options...
kluelos Posted January 31, 2012 Share Posted January 31, 2012 All of bitcomet's settings are stored in the "bitcomet.xml" file, which is nominally stored in a directory under %appdata%. A normal bitcomet update does not overwrite that file, so all of your settings and preferences are preserved. It's only if you specifically delete that file somehow, that your preferences will vanish. If you save it somewhere else, and put it back after whatever you're doing, your settings should reappear as you had them. Link to comment Share on other sites More sharing options...
Apocalypse2012 Posted January 31, 2012 Author Share Posted January 31, 2012 so why does ALLWAYS "vip" "comments" "preview" and other things I deselected show up after upgrading? Link to comment Share on other sites More sharing options...
Apocalypse2012 Posted January 31, 2012 Author Share Posted January 31, 2012 It resets after upgrading Link to comment Share on other sites More sharing options...
Apocalypse2012 Posted February 27, 2012 Author Share Posted February 27, 2012 I don't delete any files, it just resets by itself after any upgrade... Link to comment Share on other sites More sharing options...
kluelos Posted February 28, 2012 Share Posted February 28, 2012 Hmm. This doesn't happen for me. Now the column sizes aren't preserved, but they never were. Which columns are visible though, is always preserved. Why not see what happens if you save a copy of your settings file elsewhere, then recopy it into the program directory after the upgrade? Link to comment Share on other sites More sharing options...
Apocalypse2012 Posted March 15, 2012 Author Share Posted March 15, 2012 Ok, for some reason I had 2 bitcomets installed 32 and 64bits, that could be it, I will know after next update... Link to comment Share on other sites More sharing options...
