tm82 Posted March 12, 2012 Share Posted March 12, 2012 Hi! is there a possibility to save positions in a videofile analog to remember function at opening a played file? if not: is there a workaround to set remember points manually?? Thanx Link to comment Share on other sites More sharing options...
kluelos Posted March 13, 2012 Share Posted March 13, 2012 There isn't, in any player that I know of. The manual workaround is to remember or write down the elapsed time at which you stopped, and then when you re-open the file, type Ctrl-G to jump to that time, or manually drag the file-progress pointer to that time. Link to comment Share on other sites More sharing options...
