ufloding torrent in the first time, so help me please,
timysebastian
dear bitcomet team!!! thanks for your all support.
here I would like to ask few doubts regarding with afloading files using our product.
before that, I will explained what are the steps I have followed for afloading.
please correct me if I have missed anything.
1. I have selected the file.
2. in the tracker edit field, I have typed these public trackers they are,
http://open.tracker....ay.org/announce
http://www.torrent-d...o:2710/announce
http://denis.stalker...m:6969/announce
udp://denis.stalker.h3q.com:6969/announce
http://www.sumotracker.com/announce
udp://tracker.publicbt.com:80
udp://tracker.openbittorrent.com:80
udp://tracker.ccc.de:80
udp://tracker.istole.it:80
3. then I tick the publisher info check box, and type the publisher name.
4. I typed in the publisher website field www.torrentbox.com.
5. after save the file I pressed ok on, make torrent button.
I could see another page that is webseeding tab and one edit box there I typed www.torrentbox.com
so, it was announcing please type emule server.
I don't no, what I have to type there so, leave that edit box as blank.
6. I take the properties of the respective file.
then I tick 2 tick boxes under tracker page.
they are:
Share this Task in Torrent Share, and, Bypass Task Seeding Rules (task always active) tick boxes.
7. then I ufloded in to www.torrentbox.com.
8. then I redownloaded the file.
while click on download file, it was telling, task exist.
here my doubts are:
am I skipped any steps???
and how can I check weather my torrent is working or not?
I checked all trackers list, it was showing like,
http://open.tracker....iratebay.org/an... 18 0:04:31 2012-07-26 05:34:31: Tracker connection error: 10061
http://www.torrent-downloads.to:2710/... 18 0:04:34 2012-07-26 05:34:34: Tracker connection error: 10061
http://denis.stalker....com:6969/annou... 18 0:02:57 2012-07-26 05:32:57: Tracker connection error: 11004
udp://denis.stalker.h3q.com:6969/annou... 17 0:00:06 2012-07-26 05:31:05: UDP Tracker no response.
http://www.sumotracker.com/announce 18 0:04:24 2012-07-26 05:34:24: Failed to decode tracker response.
udp://tracker.publicbt.com:80 17 0:00:06 2012-07-26 05:31:05: UDP Tracker no response.
udp://tracker.ccc.de:80 0 0:09:41 1 1 logged in; 2012-07-26 05:21:01: Tracker returned 1 peeScore: 1752
iam using first time our torrent ufloder, thatsway iam asking these doubts.
so, your help will be more appriciatable .
iam attaching my torrent along with this post, kindly check weather it is working or not please,
thanks in advance yours,
Timy.
NVDA 12.torrent
Edited by cassie
Increased Font size (see edit history)
Well, the first thing to note is that the denis.stalker tracker was taken down a long time ago, so should not be included in your list. I would add that sumotorrent is among the least reliable trackers around and I would not bother with them, either. I notice that you are trying to upload to The Pirate Bay. They took their tracker down years ago, and rely on DHT and magnet links entirely, now. It's very important to visit each tracker site you want to seed at, and get current with where they are. You must include the current tracker information in order for your tracker to be accepted by the site. You must conform to the requirements for each site. There is no great advantage to spreading your torrent over dozens of sites, especially if they are private sites.
The second thing to note is that, in general, for each tracker that you list, you must then go to that tracker's web site and, as a member of this site, upload your torrent to the site. This is not true for the public trackers that will try to track any torrent anyone ever mentions to them. In general these are the trackers that use udp for their protocol.
The third thing is that when you have created the torrent you will probably begin seeding it, so you will (of course) be told that the task exists. Just click OK and the tracker data will be added to the existing task.
The fourth thing to understand is what you are trying to do with this. Are you just trying to seed it using Bittorrent? Or are you also trying to web-seed it as well? (Not recommended, you need to get your feet wet with Bittorrent before you get into the complications of web-seeding too! Are you trying to spread it via eMule? Again, not recommended, learn to bittorrent first, then when you've mastered that you can learn to use eDonkey, and then combine the two. One step at a time!
I hope you enjoy making and uploading torrents with bitcomet Timy.
Also, if you don't mind me correcting your spelling, the word is "uploading", not "ufloding". We understand you, but others may not so I thought it would be helpful to correct your spelling.
