moonhowlmax Posted October 2, 2012 Share Posted October 2, 2012 (edited) TCP Connections: Established: 73 [MAX:Unlimited] / Half-Open: 34 [MAX:200] LAN IP: 192.168.1.3 WAN IP: 115.135.244.209 Listen Port of TCP: 21306 (Blocked by Firewall/Router) Listen Port of UDP: 21306 (Opened in Firewall/Router) Windows Firewall: Added [TCP added, UDP added] UPnP NAT port mapping: Failed [uPNP device not found!] Disk Boost Service: Running I have a yellow light. I do not understand the guides of Nat port mapping since the pictures are win xp version. Anyone can help me solve this problem? my download speed is extremely slow. The download speed was high last month. Don't know why suddenly this problem happen. Please help me. Edited October 2, 2012 by moonhowlmax (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 2, 2012 Share Posted October 2, 2012 It's most likely that you need to setup portforwarding in your router. Link to comment Share on other sites More sharing options...
greywizard Posted October 3, 2012 Share Posted October 3, 2012 This guide, which is about Manual Port Forwarding, is perfectly valid for you, whatever version of Windows you may use. 1 Link to comment Share on other sites More sharing options...
