Skeltom Posted October 22, 2012 Share Posted October 22, 2012 for some reson when i start bitcomet (1.34) my port is plocked untill i say retry and check again i already opend a port in my router and it still does it but it works fine after i do it i just have to do it every time so i dont know Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 22, 2012 Share Posted October 22, 2012 sounds to me like your router and/or firewall is just slow to respond so bitcomet isn't getting the reply fast enough. This could be cause by saturated bandwidth or methods of packet scheduling, or just slow broadband speed or even a weak router, but if it always works on the second test then there is nothing to worry about, your port is open so it doesn't matter if the test completes successfully or not, the only thing that matters is the incoming connections reach you. Link to comment Share on other sites More sharing options...
cassie Posted January 19, 2013 Share Posted January 19, 2013 Well, this can't be considered a "bug" sooo... *topic moved to BitComet General Discussion* Link to comment Share on other sites More sharing options...
