Eheieh Posted December 19, 2012 Share Posted December 19, 2012 if someone can give the steps to open ports on this router i will appreciate it Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 19, 2012 Share Posted December 19, 2012 Try portforward.com, they have guides for most routers. Link to comment Share on other sites More sharing options...
kluelos Posted December 20, 2012 Share Posted December 20, 2012 That is, unfortunately, a WiMAX gateway. WiMAX is a wireless connection operating in microwave frequencies. Like just about all wireless connections, it is firewalled further upstream, so nothing you can do locally will get you an unblocked listen port. Your only option is usually to switch to some sort of wired connection. Link to comment Share on other sites More sharing options...
