alexta83 Posted February 10, 2013 Share Posted February 10, 2013 Hello, I'm trying to build an application which uses Bitcomet and I can't find any documentation nor examples to how to use BitCometAgentLib and BitCometBHOLib. I need them in order add a new file into Bitcomet and to make Bitcomet to begin the download. I will be very thankful for any kind of help or guidance for this matter. My problem, at this point, is to add a torrent file to Bitcomet because of the confirmation part (I want to automate the confirmation). Thanks Alex Link to comment Share on other sites More sharing options...
queeniequ Posted February 16, 2013 Share Posted February 16, 2013 Well, I don't think it would be a good idea to skip the confirmation part. Still I'll convey your suggestion to our technical staff. Thank you for your support! Link to comment Share on other sites More sharing options...
alexta83 Posted February 19, 2013 Author Share Posted February 19, 2013 Hi, thanks for the response. What I mean is that I need the ability to add a torrent file to bit comet automatically by using BitCometAgent or something like this. Alex Link to comment Share on other sites More sharing options...
