Help setting up the Virus Scan option for Kaspersky PURE, please?
I'm trying to setup the AV scan upon completion of a torrent download, but it's not automatically discovering I'm using Kaspersky Pure. So I'm guessing that I have to set it up manually, but I don't really know much about basic command line stuff. So I was hoping someone here would be kind enough to assist in discovering how to set it up. :D
Thanks in advance for any assistance, and let me know if you need any details aside from I'm using the current version of BitComet, running the latest Kaspersky PURE 2 and I'm on Windows 7 x64.
I strongly recommend you to consult the help file of Kaspersky PURE and add BC to the auto-scan list.
Alright, I hope I don't sound silly asking, but what exactly should I be searching for? I've already looked into the help file and I'm not seeing anything of help that fits this (or at least that I understand heh). I'm seeing an auto-block, but not an auto scan. :/
  • 2 weeks later...
You have to search the help files or online, for command line (and switches) syntax, that will allow you to start the antivirus scanning module by typing a text command in any command line interpreter (such as cmd.exe) and start the scanning of a specific file.
Once you figured out the exact command you can type it in the proper BitComet option page and theoretically it should work.
