larry_patt Posted May 20, 2013 Share Posted May 20, 2013 I recently started using Expat Shield to mask my IP but bitcomet won't doanload. It will load the torrent and will start the download as soon as I turn Expat off. It did the same thing with Hide My IP. What can I do? Is there a better IP blocker that works better with Bitcomet? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 22, 2013 Share Posted May 22, 2013 You cannot expect someone to send you data if you don't tell them the correct address to send it. The only way you can be anonymous when using p2p is if you rent a computer in an area of the world that doesn't provide their customers info to other countries, then you would need to connect to the internet through that computer, or run your torrent client on that computer. Link to comment Share on other sites More sharing options...
