Login Problem
JusJas
Try running bitcomet "as administrator" by "right click" on the icon on desktop or start menu and select "run as administrator". See if that makes a difference.
If still fails, please answer this two questions.
Are you able to log into your account at cometID.com?
Do you use any IP address filtering programs or block lists?
  • 1 year later...
To everyone concerned about CometID, yes it's down, this happens sometimes with websites just like it does with your personal computer, errors occur and need to be fixed. Large commercial websites like Google and Amazon have many backup servers running and staff on duty 24/7 to fix problems, but BitComet being a free service is maintained by volunteers and it will be fixed as soon as someone on the development team has the time to fix it. I have notified them of the outage and I expect it will be up and running by monday, if not sooner.
In the mean time you can continue to use BitComet, it will still work as good as any other bittorrent client and only some of it's more advanced features like LTseed snapshots, search for mirrors etc will be affected by the outage.
  • Like 1
Guest
