Treebeard431 Posted July 21, 2013 Share Posted July 21, 2013 I just want to double check on something I think I read on a page in BitComet somewhere, a few weeks ago. It said that if I'm using USB Wireless Adapters to get my signal, I will never be able to get my Listen Port to open. Can anyone answer this for me? Thank you! Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted July 22, 2013 Share Posted July 22, 2013 There is no problem using usb adapters, it depends on the type of connection. If you're using a wwan or celular type of internet connection, then you will usually be blocked. If it's a wifi adapter that connects to a router you control, then it shouldn't be a problem. Link to comment Share on other sites More sharing options...
