wendy1854 Posted August 31, 2013 Share Posted August 31, 2013 I just paid for 1 month of VIP acceleration status and nothing is happening . I signed in and I read all of the instructions on how to use it . but nothing is happening . Can someone tell me what am I doing wrong ? I have ADSL and I am using windows 7 64 bit OS And I have Norton's 360 premier edition. I would appreciate any help that you could give on this matter . 1 Link to comment Share on other sites More sharing options...
arigatokuzaimas Posted September 1, 2013 Share Posted September 1, 2013 (edited) HI..wendy1854; hope this will helps you... (1) open bitcomet, makesure it's auto login & internet is ON (2) download any torrent file with bitcomet or you can download torrent from your bitcomet torrent history then select all download (left menu) (3) stop downloading & right click torrent file & select properties (4) now you can see the menu...next to General is VIP Acceleration so select the menu (5) click enable & what so on if it is NOT enable yet & wait till preparing is done (6) DO NOT FORGET to enable anonymous download's too - especially for direct download (7) select ADVANCE & check Bypass Task...... & Enable Task Specific ........ download rate Max: unlimited, upload rate Max: 10 & 3 kB/s (8) press OK, exit bitcomet & restart computer... I THINK IT'LL HELPS. if you still face the same problem...the best choice that you got is to contact BITCOMET SUPPORT here's the pic for your ref: Edited September 1, 2013 by arigatokuzaimas (see edit history) Link to comment Share on other sites More sharing options...
arigatokuzaimas Posted September 1, 2013 Share Posted September 1, 2013 (7) select advanced menu check bypass task....... & enable specific......for download rate Max: UNLIMITED, for upload rate MAX: 10 & Min: 3 kB/s 1 Link to comment Share on other sites More sharing options...
tubbster999 Posted September 13, 2013 Share Posted September 13, 2013 (edited) Hi, I signed up 4 the 100g vip acceleration and its not working, i'm using acer laptop windows 7, 32bit os and avast security. On the main screen of bitcomet I have a message at bottom saying your listen port is blocked. Please check your firewall and NAT router config. Help please very new to this Edited September 13, 2013 by tubbster999 (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 13, 2013 Share Posted September 13, 2013 Hi, I signed up 4 the 100g vip acceleration and its not working, i'm using acer laptop windows 7, 32bit os and avast security. On the main screen of bitcomet I have a message at bottom saying your listen port is blocked. Please check your firewall and NAT router config. Help please very new to this Please make a new topic after reading the topic linked in my signature. We'll help you solve your port problem first, that will make a big difference in performance then we can look at what issues you are having with vip. Link to comment Share on other sites More sharing options...
arigatokuzaimas Posted October 21, 2013 Share Posted October 21, 2013 @ tubbster999 for your info, most of the antivirus especially for internet security will filtered all incoming data. thats why bitcomet NAT indicates yellow but you still get a great download speed even it is in yellow color. Check your IGMP for more info...i agreed with The Unusual Suspect... Thanks man... Link to comment Share on other sites More sharing options...
