golden_gate Posted January 14, 2014 Share Posted January 14, 2014 Hi guys, I am wanting to know if there is or will possibly be any integration for BitComet & Open VPN's? As no connection is 100% up, drop outs can occure leaving my connection unprotected while still torrenting. Ive found this numerous times of late. I have heard that Vuze is the 1 main client that intergrates a VPN connection service, it stops downloading if the VPN connection is disconnected or interupted. http://torguard.net/blog/vpn-disconnect-solution/ There are a couple software options which do this, but it makes more sense for it to be in the torrent client rather than using 1 software monitor 2 others & control bitcomet. http://torrentfreak.com/how-to-shut-down-utorrent-automatically-when-your-vpn-disconnects-130707/ I dont want to change clients, I quite like BitComet, and rather not use another software - if I dont have to... whats the go in this please?? thanks in advance Link to comment Share on other sites More sharing options...
