bitcomet 1.36 score problems.
midnight50
hello,i have a problem with my scoring and ranking and 0% per cent the problem is my title went to lieutenant colonel,i have downloaded since,my ranking goes up now on 770252 but my score has only gone up from 13634 to 13646.and my 0% percentage has stayed the same,the blue line has not moved you can find all this on the bottom left hand corner of bitcomet as they all were working fine untill my title changed,i would like to know if anybody could help me with this matter please.
many thanks from
midnight50
How was the score calculated?
BC Score = Points from online time + Points from uploaded Bytes.
  • Being online can generate 2 points per hour, with a limited maximum of 20 points, per day.
  • Uploading files continually, via BitTorrent protocol, can generate 1 point per 10MB, with a limited maximum of 100 points, per day.
  • Downloading files, via BitTorrent protocol, doesn't affect the Score. The same applies to HTTP and FTP protocol.
  • The Score will be updated every 24 hours.
The "Ranking" is the number of people that have a higher score than you, if your ranking was 1, you'd have the highest score in the world.
  • Like 1
