need codecs
Jago
First I should warn you that installing improper or conflicting codecs can make your system unstable, but if you haven't installed any then I would recommend getting one of the popular codec packs like those offered by K-lite or CCCP
http://codecguide.com/download_k-lite_codec_pack_full.htm
http://www.cccp-project.net/
  • 4 months later...
ok, yes I know this reply is about 5 months late, but K-Lite Codec Pack works good for me.
