Hammadymn Posted February 3, 2014 Share Posted February 3, 2014 Hi there I have been using bitcomet for 3 monthes and every thing was just fine suddenly it,s stopped and started to get trackers connection errors 10060 - 10061- 10051 I have 1mb adsl with D-Link router and Windows 7 32bit I had bitcomet 1.36 .. I tried to update it to 1.37 then uninstall it and install again and still nothing changed .. what can I do please Best Regards Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted February 4, 2014 Share Posted February 4, 2014 Your screenshot doesn't tell us much, the piratebay tracker hasn't been used in years so it's normal to get this error on all of their torrents, they are now trackerless. Not sure about torrentbay.to and the other listed trackers haven't shown any errors. It's very common to have dead trackers in older torrents and many newer torrent authors just add random trackers out of ignorance. The only obvious problem you have is a blocked listening port which will cause poor performance, but won't prevent you from downloading. Link to comment Share on other sites More sharing options...
