I finds alot of seed and starts to download at high speed but then stops
I try to download files with version 1.37 They start find peers seeds Help and start to download. But it appears to time out and a red x appears and will not start again until i press start button.. It then repeats the samething again. Help anyone? file Byantium 2012 brrip .xvid ac3 war. max download rate 921 bps conencted to 10 seed 436 peers. Looses DTH network... Changing default directory Helped...
Regards.
Brad
The red "x" will provide more info if you hover over it with the mouse. It could be that your drive doesn't have room, or that your user account doesn't have access to write in that folder, or it could indicate that there is a problem with your drive and/or file system.
