How do I change the IP in BitComet listen port box in window bottom right corner
I was connected to my listen port now all of a sudden I'm not. The IP I have noticed is not the same as the one I am familiar with. Can I change that, how did it change and how do I find the right IP to fill in there? And if it is right all my ports are forward correctly what else could be the issue if the IP isnt wrong?
If you're referring to the WAN address, yours is... : 24.13.31.XXX (last segment removed to protect your privacy). This IP is assigned by your internet provider and if you only have the one computer connected, it will use this IP, if you have a router installed then your computer will be assigned a different IP within your local area network (LAN).
