nottonto Posted August 11, 2014 Share Posted August 11, 2014 Hi everyone, I could do with a little help please. When I download a movie and play it on my TV using a HDMI cable the video part is fine but the audio plays through my laptop speakers, not my TV speakers, is there any setting I need to adjust to make the TV speakers work ? I'm using Windows 7, IE 10 and VLC player. I have downloaded movies using VUZE and don't have this problem so I know that my equipment is fine. thanks for any help, nottonto Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 11, 2014 Share Posted August 11, 2014 This has noting to do with BitComet or Vuse, both clients simply download the files you select, they don't and cannot change them or alter the way they playback. Your issue is with the player you're using or the type of files you're downloading. Since you are using VLC player, their forum would be the obvious choice to seek help. Link to comment Share on other sites More sharing options...
