fbali_4_ever123 Posted September 3, 2014 Share Posted September 3, 2014 hi guys i'm using the latest BitComet 1.37 64-bit and i'm having trouble forwarding my port , im using a linksys EA6300 , i started the process by selecting single port forwarding and i entered my ip address , but i cant seems to know what is the external and internal port i tried entering the same listen port that im using but BitComet keeps saying the the listen port is blocked can someone please help me Link to comment Share on other sites More sharing options...
fbali_4_ever123 Posted September 3, 2014 Author Share Posted September 3, 2014 sorry guys i forgot to put some additional information im using windows 8.1 64-bit and bitdefender internet security 2015 and i have a 100m fiber connection Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 3, 2014 Share Posted September 3, 2014 The external and internal port are the same, you want all traffic on that port redirected to the same port on your local computer so you were correct in using the bitcomet listening port in both. I suggest you confirm if the port is actually blocked. If you are getting remote peer connections, then the port is open, if they are all local, you most likely have a problem. You can also check the port at canyouseeme.org, just enter the port number and it will try to see if it can connect. If it cannot, this means it's being blocked somewhere along the route and this could be a firewall installed on your computer or a problem with the router. Link to comment Share on other sites More sharing options...
fbali_4_ever123 Posted September 3, 2014 Author Share Posted September 3, 2014 thank you for replying i checked my port at canyouseeme.org and it says ((Connection refused)) what could be causing this ? and thank you Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 3, 2014 Share Posted September 3, 2014 This is usually caused by a firewall or other security software blocking incoming connections, or a router that doesn't properly forward the port from your WAN IP address to your LAN address. If it's possible to remove the router you can confirm if the problem is with your computer or with the router, if it's with the computer the first place to look would be your internet security software, if it's the router the best advice I can give you is to seek help with the manufacturer. I don't have any experience with that model of router so cannot tell you how to properly forward your port, but we do have a comprehensive article on this subject posted at wiki.bitcomet.com and I think it would be beneficial to read it. I'd recommend starting here... http://wiki.bitcomet.com/add_port_mapping_in_nat_router Link to comment Share on other sites More sharing options...
AbhinavChalisez Posted September 14, 2014 Share Posted September 14, 2014 Hey In a simple way I don't know what you were saying. So, Please stp. Link to comment Share on other sites More sharing options...
cassie Posted September 14, 2014 Share Posted September 14, 2014 Hey In a simple way I don't know what you were saying. So, Please stp. What part did you not understand? Why would you want someone who is trying to help the original poster to stop? If you have a question of your own, please open your very own thread and expose your query, after reading this. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 15, 2014 Share Posted September 15, 2014 Don't worry cassie, if they don't want to understand how their local area network works then they shouldn't have installed a router and until the learn to follow instructions, they aren't likely going to find any help. They should probably learn some manners too and not interrupt in someone else's topic so if they don't explain their odd behavior in the next day or so you can remove their post and our replies and return this post back to the original author who may still need help. Link to comment Share on other sites More sharing options...
cassie Posted September 17, 2014 Share Posted September 17, 2014 I agree. To all other users, please take note. Link to comment Share on other sites More sharing options...
ctrn Posted October 22, 2014 Share Posted October 22, 2014 I have the problem of listen port bloked ( yellow icon in my bitcomet . I used windows 8.1 try to read on this forum but the document show on XP and windows 7 config port forwarding. How I config port forwarding in windows 8.1 , anyone please help. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 23, 2014 Share Posted October 23, 2014 I have the problem of listen port bloked ( yellow icon in my bitcomet . I used windows 8.1 try to read on this forum but the document show on XP and windows 7 config port forwarding. How I config port forwarding in windows 8.1 , anyone please help. Port forwarding is not done in windows, it's done in your router. If you are serious about wanting help, make your own topic and include ALL the requested information Link to comment Share on other sites More sharing options...
ajttanbc Posted December 25, 2015 Share Posted December 25, 2015 You need to login in your router account to do the setting. Look for port triggering setting. Set the trigger port numbers and external port numbers same as your listen port numbers. Save the setting. Link to comment Share on other sites More sharing options...
