diver999 Posted December 27, 2014 Share Posted December 27, 2014 Hi, I am new to this forum, but have been using Bitcomet for many years with no problem. I have Bitcomet 1.37 (64 bit), Firefox browser, broadband connections and windows 7 on one pc and windows 8.1 on another pc. I purchased a new laptop last month and eventually downloaded bitcomet. When I entered a serach in "thePiratebay" box, after a few minutes I got a message that the PC had timed out. I tried the old PC and got the same message. Know when I put in a serach i get the screen as attached. This appaear to be counting up in seconds. The screen image does not show it, but at the top of the page there is the Bitcomet logo and links to "top rated movies" "transformers" etc. I went back to my old pc and got exactly the same. Can anyone help me please Regards EricThe Pirate Bay.pdf Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 27, 2014 Share Posted December 27, 2014 ThePirateBay was shut down on December 9th. Link to comment Share on other sites More sharing options...
diver999 Posted December 27, 2014 Author Share Posted December 27, 2014 Thanks- What do I use instead? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 27, 2014 Share Posted December 27, 2014 There are hundreds of torrent sites, tpb was the default since it's the biggest but you can try any of them, some are listed in bitcomet and there are countless others that aren't. I won't recommend any specific sites you just need to look until you find one you like. 2 Link to comment Share on other sites More sharing options...
dragon66dem Posted May 5, 2015 Share Posted May 5, 2015 (edited) you can use kickass torret very good site and demonoide is back I have problem when I load /start my bitcomet for downloading torents it is not signing me in changed my password and installed version 138/64 bit and still not signing me in ! help!! Edited May 5, 2015 by dragon66dem (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 6, 2015 Share Posted May 6, 2015 As previously mentioned the server was fixed after the development team returned from the holiday weekend, but a harddrive error caused another issue. It's back up and running now so lets hope for the best. Link to comment Share on other sites More sharing options...
