rodspri Posted December 11, 2015 Share Posted December 11, 2015 I have a 64-bit computer running Windows 8.1 64-bit. I have installed BitComet 64-bit but 32-bit was not uninstalled & the old directory is still there. Windows 'Programs & Features' and 'Revo Uninstaller' both now have no 'history' of Bitcomet 32-bit install. Is there any problem deleting the Bitcomet 32-bit directory(folder) ? AND/OR are there any files I should keep/copy and place into the 64-bit directory(folder) ? Any other potential problems or actions I should be aware of ? Thanks, Rod Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 12, 2015 Share Posted December 12, 2015 you should be able to delete it if it bothers you, or you can first rename the folder and make sure everything works properly, then delete. Link to comment Share on other sites More sharing options...
