mcKOOKIEZ Posted May 26, 2016 Share Posted May 26, 2016 (edited) Hello everyone, I've tried already reading all kinds of posts and guides all around the web but I couldn't get my port opened lol. I've followed a guide in portforward.com, still my port is closed. 1) BitComet 1.40 2) I'm not sure what kind of internet connection I have. 3) Router: Dlink DSL-6850u, a VDSL modem + router given by Israeli telecom provider Bezeq. 5) Windows 10 64Bit, Eset Smart Security 9. I tried forwarding port 27225, made exceptions and rules in ESS9, turning on uPnP in my router and enabling it in ESS9 and Windows. I have a local static IP, but my remote IP is changing, is that okay? BitComet statistics: TCP Connections: Established: 0 [MAX:Unlimited] / Half-Open: 14 [MAX:200] LAN IP: 10.0.0.5 WAN IP: 109.65.XX.XX Listen Port of TCP: 27225 (Blocked by Firewall/Router) Listen Port of UDP: 27225 (Opened in Firewall/Router) Windows Firewall: Added [TCP added, UDP added] UPnP NAT port mapping: Failed [Dlink (http://www.dlink.com/)] Disk Boost Service: Running Overall Download Rate: 0 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task Overall Upload Rate: 0 kB/s [MAX:Unlimited] (for not downloading) LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0 Memory Usage: Working Set: 85.42 MB, Commit Size: 88.75 MB Free Memory: Phys: 13.23 GB (Min to keep: 50 MB), Pagefile: 15 GB, Virtual: 131,039 GB Disk Cache Size: 0 B (Min: 6 MB, Max: 50 MB) Disk Read Statistics: Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0% Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0% UPnP Test Program v1.16 Copyright Mark Gillespie 2010: TEST 1 - Operating System Support - PASSED TEST 2 - SSDP Service Running Check - FAILED TEST 3 - SSDP Service Automatic Check - FAILED TEST 4 - UPnPHost Service Running Check - FAILED TEST 5 - UPnPHost Service Automatic Check - FAILED TEST 6 - UPnP Framework Firewall Exception Check - PASSED TEST 7 - Adapter #0 - 10.0.0.5 - FAILED TEST 8 - Get External IP Address - FAILED canyouseeme.org: Error: I could not see your service on 109.65.XX.XX on port (27225) Reason: Connection timed out Edited May 26, 2016 by cassie IP elided for privacy reasons (not a good idea to post it on a public forum...) (see edit history) Link to comment Share on other sites More sharing options...
GandalfTheWizard Posted May 26, 2016 Share Posted May 26, 2016 (edited) UPnP UPnP mapping does not work in all cases; you might need to forward your port manually. Follow this tutorial to forward your port on your router: https://www.youtube....h?v=HGPrN62QTZw -- if you say you already have a static IP, you can skip some steps: https://youtu.be/HGPrN62QTZw?t=190 PS: Make sure you forward for both TCP and UDP. Also, restart BitComet to validate the new settings. Internet Connection Please do some research, and tell us what kind of internet connection you have. It is crucial, as this might be a reason for your ports to be able to be forwarded or not. VDLS Modem Hmm... Modem... According to this article, your modem is incorporated within your router, is that correct? Edited May 26, 2016 by GandalfTheWizard (see edit history) Link to comment Share on other sites More sharing options...
cassie Posted May 26, 2016 Share Posted May 26, 2016 I'm not sure what kind of internet connection I have. The easiest way of doing this is to call your ISP and ask them directly...they should be able to tell you if you have (for example) an ADSL connection, or a 3G/4G WiFi connection, fiber optic... :) 1 Link to comment Share on other sites More sharing options...
mcKOOKIEZ Posted May 27, 2016 Author Share Posted May 27, 2016 UPnP UPnP mapping does not work in all cases; you might need to forward your port manually. Follow this tutorial to forward your port on your router: https://www.youtube....h?v=HGPrN62QTZw -- if you say you already have a static IP, you can skip some steps: https://youtu.be/HGPrN62QTZw?t=190 PS: Make sure you forward for both TCP and UDP. Also, restart BitComet to validate the new settings. Internet Connection Please do some research, and tell us what kind of internet connection you have. It is crucial, as this might be a reason for your ports to be able to be forwarded or not. VDLS Modem Hmm... Modem... According to this article, your modem is incorporated within your router, is that correct? Thank you very much, this guide helped me :) All I missed was 'Static IP Lease' or something like that. Link to comment Share on other sites More sharing options...
GandalfTheWizard Posted May 27, 2016 Share Posted May 27, 2016 You're welcome, as usual :) Link to comment Share on other sites More sharing options...
