gXpyhAnz Posted August 15, 2016 Share Posted August 15, 2016 Hi why the snapshot icon is like that? I think this is not the normal snapshots icon Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 15, 2016 Share Posted August 15, 2016 could be a codec problem, you system may not have the proper codecs to display the snapshot, or perhaps it couldn't be downloaded. Are you using any ip filters? Link to comment Share on other sites More sharing options...
gXpyhAnz Posted August 15, 2016 Author Share Posted August 15, 2016 could be a codec problem, you system may not have the proper codecs to display the snapshot, or perhaps it couldn't be downloaded. Are you using any ip filters? IP Filters? Do you know where to download proper codecs? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 15, 2016 Share Posted August 15, 2016 Do you use PeerBlock, PeerGuardian, Protowall or similar apps that use IP blocking lists? As for codecs, if you don't understand this, then it's not wise to mess with it especially since we don't know the cause for your snapshots not displaying, it could be that they are simply not available. Link to comment Share on other sites More sharing options...
gXpyhAnz Posted August 15, 2016 Author Share Posted August 15, 2016 Do you use PeerBlock, PeerGuardian, Protowall or similar apps that use IP blocking lists? As for codecs, if you don't understand this, then it's not wise to mess with it especially since we don't know the cause for your snapshots not displaying, it could be that they are simply not available. No I don't use it. This appear since someone help me to remove some malware using farbar tool Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 15, 2016 Share Posted August 15, 2016 sounds like it removed something it shouldn't. Try removing and installing bitcomet. Link to comment Share on other sites More sharing options...
gXpyhAnz Posted August 16, 2016 Author Share Posted August 16, 2016 sounds like it removed something it shouldn't. Try removing and installing bitcomet. Already did that Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 19, 2016 Share Posted August 19, 2016 I suspect the problem is with Internet Explorer then. Link to comment Share on other sites More sharing options...
