ashtu109 Posted August 23, 2016 Share Posted August 23, 2016 Well I just started using peerblock and I was actually paying attention to it today and mind you I only download music and game torrents....but peerblock was blocking my ip as the source to several differnt loc. saying shares illegal p***, underage p*** and the like. anti virus isn't detecting anything that would do that so whats the deal? Link to comment Share on other sites More sharing options...
ashtu109 Posted August 23, 2016 Author Share Posted August 23, 2016 I double checked, it is only doing it while BC is running and doing transfers. Link to comment Share on other sites More sharing options...
ashtu109 Posted August 23, 2016 Author Share Posted August 23, 2016 on a whim I tried a different torrent client and just started it wasn't d/l or u/l and was doing the same thing is this some kind of sick joke? Link to comment Share on other sites More sharing options...
Rhubarb Posted August 23, 2016 Share Posted August 23, 2016 It's just possible you know that peerblock is doing exactly what the name says - blocking peers Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 25, 2016 Share Posted August 25, 2016 Exactly, it's blocking peers, in most cases harmless ones. It depends on what block lists you use. Also, you may be disabling Bitcomet's ability to search for mirror locations to download. To work properly with peer block you should make an allow list including the IPs used by bitcomet which can be found in the FAQs at wiki.bitcomet.com. Link to comment Share on other sites More sharing options...
