Eusebio90 Posted April 25, 2017 Share Posted April 25, 2017 (edited) Salut, am o problema cu Bitcomet, pana acum 2-3 zile mi a mers perfect, acum incerc sa iau un film si nu mai porneste descarcarea, am bitcomet 1.45 pe win 7 ........................ (Loose translation) Hello, I have a problem with BitComet: Until about 2-3 days ago, it was working perfectly, but now I try to download a movie and the download doesn't start. I use BitComet 1.45 and WIN 7 Edited May 1, 2017 by cassie (see edit history) Link to comment Share on other sites More sharing options...
andrei911 Posted April 29, 2017 Share Posted April 29, 2017 (edited) Salut, toti avem aceeasi problema, ma gandesc ca vrei sa descarci de pe filelist, nu mai merge cu bitcometu trebe sa instalezi alt program. ............................ (Google translation) Hello, we all have the same problem. I think you want to download from the filelist,It does not work with BitComet. You need to install another program. Edited May 1, 2017 by cassie (see edit history) Link to comment Share on other sites More sharing options...
cassie Posted May 1, 2017 Share Posted May 1, 2017 Eusebio90, You have to provide a LOT more information about how your BitComet is setup (configuration, router, etc.), before we can attempt to begin to help you. Please read here and provide as much detail informaion as possible. Eusebio90, Trebuie să furnizați mai multe informații despre configurarea dispozitivului BitComet (configurație, router etc.), înainte de a încerca să începem să vă ajutăm.Vă rugăm să citiți aici și să oferiți cât mai multe informații detaliate posibil. Link to comment Share on other sites More sharing options...
cassie Posted May 1, 2017 Share Posted May 1, 2017 On 4/29/2017 at 5:42 PM, andrei911 said: Salut, toti avem aceeasi problema, ma gandesc ca vrei sa descarci de pe filelist, nu mai merge cu bitcometu trebe sa instalezi alt program. ............................ (Google translation) Hello, we all have the same problem. I think you want to download from the filelist,It does not work with BitComet. You need to install another program. Expand How can you give Eusebio90 this "advice" if you don't even know what his configuration is like or what his problem truly is? This help is as useful as someone saying "My car doesn't work" and you replying "we all have the same problem...you need to get another car". ............................ Cum se poate da Eusebio90 acest "consiliere“, dacă nici măcar nu știu ce configurație este ca Lui sau ceea ce este cu adevărat problema lui? Acest ajutor este la fel de util ca cineva spunând „Mașina mea nu funcționează“ și răspundeți „noi toți avem aceeași problemă ... aveți nevoie pentru a obține un alt automobil“. Link to comment Share on other sites More sharing options...
