pinkydemon Posted December 27, 2017 Share Posted December 27, 2017 Hello. I have a problem with downloading bittorrent files. I was unable to download bittorrent files since last month and I keep seeing the message "Port Detection Failed." I checked Bitcomet for Firewall exception but it never helped me all. What is wrong with this and how can I solve it? (My current Bitcomet is 32 bit with version 1.47 and I am using Verizon FiOS.) Link to comment Share on other sites More sharing options...
Rhubarb Posted December 27, 2017 Share Posted December 27, 2017 If you can, set the computer for a fixed ip and then set the router for port forwarding to that IP number. You also need to set the ports for that and match the port in Bitcomet (make it fixed and not random) Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 (edited) Whose IP are you talking about and how can I fix it? Edited December 28, 2017 by pinkydemon (see edit history) Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 3 hours ago, Rhubarb said: If you can, set the computer for a fixed ip and then set the router for port forwarding to that IP number. You also need to set the ports for that and match the port in Bitcomet (make it fixed and not random) Whose IP are you talking about? Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 4 hours ago, Rhubarb said: If you can, set the computer for a fixed ip and then set the router for port forwarding to that IP number. You also need to set the ports for that and match the port in Bitcomet (make it fixed and not random) I have these IPs (I have excluded my parents' IP and my iPhone's IP because they are not related.); 192.168.1.3 (mine, Ethernet) 192.168.1.11 (Ethernet) 192.168.1.40 (Ethernet) 192.168.1.5 (android-632c42706d3c6394, Wireless) 192.168.1.7 (SAMSUNG-SM-G930A, Wireless) Which IP are you talking about? Link to comment Share on other sites More sharing options...
Rhubarb Posted December 28, 2017 Share Posted December 28, 2017 Go to network settings and fix your IP to 192.168.1.3 and the gateway to 192.168.1.1. Open the router with your browaser (http://192.168.1.1) and set port forwarding to 192.168.1.3 on a fixed port (preferably in the high numbers) and set that port number in Bitcomet Check here for further info Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 28, 2017 Share Posted December 28, 2017 regarding your report: Topics have a time limit to edit which is necessary because some members have changed posts rendering a thread impossible to understand, so we lock the post after about 30 mins Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 4 hours ago, Rhubarb said: Go to network settings and fix your IP to 192.168.1.3 and the gateway to 192.168.1.1. Open the router with your browaser (http://192.168.1.1) and set port forwarding to 192.168.1.3 on a fixed port (preferably in the high numbers) and set that port number in Bitcomet Check here for further info TCP, UCP, or both? Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 9 hours ago, pinkydemon said: I have these IPs (I have excluded my parents' IP and my iPhone's IP because they are not related.); 192.168.1.3 (mine, Ethernet) 192.168.1.11 (Ethernet) 192.168.1.40 (Ethernet) 192.168.1.5 (android-632c42706d3c6394, Wireless) 192.168.1.7 (SAMSUNG-SM-G930A, Wireless) Which IP are you talking about? 4 hours ago, Rhubarb said: Go to network settings and fix your IP to 192.168.1.3 and the gateway to 192.168.1.1. Open the router with your browaser (http://192.168.1.1) and set port forwarding to 192.168.1.3 on a fixed port (preferably in the high numbers) and set that port number in Bitcomet Check here for further info Oh, I forgot this one; 192.168.1.2 (w7P-PC, Ethernet) Link to comment Share on other sites More sharing options...
pinkydemon Posted December 28, 2017 Author Share Posted December 28, 2017 Oh, wait. I have tried my IP address(173.66.150.14) with the same thing but it never helped at all. Link to comment Share on other sites More sharing options...
pinkydemon Posted December 29, 2017 Author Share Posted December 29, 2017 I still cannot download bittorrent files since last month. What is wrong with it? Link to comment Share on other sites More sharing options...
pinkydemon Posted December 29, 2017 Author Share Posted December 29, 2017 My DHT is connected and the port is open(I checked the port with a program and found out that my port is opened.) but I still see the message "Port Detection Failed." What is happening and how can I solve this? Link to comment Share on other sites More sharing options...
cassie Posted December 30, 2017 Share Posted December 30, 2017 Please do not open a new thread as a continuation of another one...it'll just make everyone reading it very confused. Keep further posts (assuming that they're about the same issue) in the same thread. *Post merged into Original Thread* Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted January 2, 2018 Share Posted January 2, 2018 try right clicking and retest port Link to comment Share on other sites More sharing options...
pinkydemon Posted January 6, 2018 Author Share Posted January 6, 2018 On 1/2/2018 at 12:11 AM, The UnUsual Suspect said: try right clicking and retest port How? Besides, I have uninstalled the updates of Windows 10 Pro but it never helped at all. Link to comment Share on other sites More sharing options...
pinkydemon Posted January 8, 2018 Author Share Posted January 8, 2018 Here is what I see: DHT Connected: 8 Port Detection Failed (Gray Light) What is wrong with this and what should I do? Link to comment Share on other sites More sharing options...
pinkydemon Posted January 9, 2018 Author Share Posted January 9, 2018 2 hours ago, pinkydemon said: Here is what I see: DHT Connected: 8 Port Detection Failed (Gray Light) What is wrong with this and what should I do? Wait. Here is my Statistics: TCP Connections: Established: 0 [MAX:Unlimited] / Half-Open: 0 [MAX:200] LAN IP: 192.168.1.3 WAN IP: Listen Port of TCP: 12404 (Detect Failed) Listen Port of UDP: 12404 (Detect Failed) Windows Firewall: Added [TCP added, UDP added] UPnP NAT port mapping: Added Disk Boost Service: Not Installed Overall Download Rate: 0 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task Overall Upload Rate: 0 kB/s [MAX:Unlimited] LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0 Memory Usage: Working Set: 67.42 MB, Commit Size: 95.42 MB Free Memory: Physical: 1.36 GB/3.21 GB (Min to keep: 50 MB), Virtual: 4.53 GB/6.46 GB, Process: 1.53 GB/1.99 GB Disk Cache Size: 0 B (Min: 6 MB, Max: 1024 MB) Disk Read Statistics: Request: 0 (freq: 0.0/s), Actual Disk Read: 0 (freq: 0.0/s), Hit Ratio: 0.0% Disk Write Statistics: Request: 0 (freq: 0.0/s), Actual Disk Write: 0 (freq: 0.0/s), Hit Ratio: 0.0% Total Downloaded: 6.77 KB (this session: 6.77 KB) Total Uploaded: 1.11 KB (this session: 1.11 KB) (I have excluded Up Time and Overall Tasks.) Link to comment Share on other sites More sharing options...
pinkydemon Posted January 9, 2018 Author Share Posted January 9, 2018 Good news! I just reset the router and worked! Link to comment Share on other sites More sharing options...
