binaya80 Posted May 7, 2018 Share Posted May 7, 2018 (edited) Whenever I add a torrent using a Magnet link, It just hangs, or lag for 10-20 Seconds. Then it starts to work again. I have an SSD.. At the same time, I can see my Disk uses it only up to 2-3% With the processor uses up to 10-20 % , It's as usual for my proecessor... Clock at 3.00GHZ ? What could be the problem.. I'm on 64Bit with the latest Setup! Edited May 7, 2018 by binaya80 (see edit history) Link to comment Share on other sites More sharing options...
Rhubarb Posted May 7, 2018 Share Posted May 7, 2018 Magnet links do take a bit longer to kick in as opposed to a .torrent file. That's perfectly normal. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 14, 2018 Share Posted May 14, 2018 the delay using magnet links is finding peers and downloading the torrent so the task can begin. Link to comment Share on other sites More sharing options...
