Bitcomet 1.51 is live and avaialable for downloads
Version v1.51 released on  2018.6.12
GUI Improved: new settings in Tracker page of option window, automatically add trackers when start BitTorrent download
GUI Improved: new settings in Tracker page of option window, automatically update trackers list every day
GUI Improved: increase max value for global rate limit, task rate limit and scheduler rate limit from 9999kB/s to 100MB/s
GUI Improved: improve support for high-DPI monitor
GUI Bugfix: unsupport download torrent file from HTTPS link
GUI Bugfix: remove P2PCache function from Advanced page of Option window, which was out-of-service for a long time
Core Improve: improve download speed stability of BitTorrent downloading
Core Improve: increase max download speed of single connection of BitTorrent downloading
Core Improve: refine Crash Report program
Core Bugfix: fix problems when exit program while high-speed downloading
https://www.bitcomet.com/en/changelog
https://www.bitcomet.com/en/archive
Wonder if any ISP actually  officially supported this P2Pcache feature
On 6/20/2018 at 5:50 AM, SFD96 said:
Whoa ! This is something new and really cool !
More info here http://wiki.bitcomet.com/bitcomet_options#tracker
Not really fond of this option, if you are adding trackers that the torrent isn't registered in then you are only spamming the tracker with unwanted traffic and potentionally shutting down trackers. it's kinda like if someone thought it would help their phone calls complete if they added random phone numbers to be dialed, causing the owners of those numbers a lot of grief.
If you add only open trackers, or if bitcomet would automatically remove any tracker that did not accept the torrent, then this could be a good option.
