bemused11 Posted August 21, 2018 Share Posted August 21, 2018 Hi I have been using bitcomet for years without problem but since upgrading to 1.51 my D/L speeds are ridiculously low and it is difficult to do anything on my pc whilst downloading. Is 1.51 defective? I have uninstalled and reinstalled with no difference. please help 1 Link to comment Share on other sites More sharing options...
cassie Posted August 30, 2018 Share Posted August 30, 2018 Have you changed any of your settings (opened ports, etc), added any new programs (new router/firewall/antivirus), or changed ISP recently? Link to comment Share on other sites More sharing options...
rubent22 Posted September 9, 2018 Share Posted September 9, 2018 i am experiencing the same issues as other posted mentioned.100% cpu usage etc,no new programs and no changes to file settings on bit comet.only happened with last update of program,before that it was running fine and still able to use computer,without anything being slowed down. Link to comment Share on other sites More sharing options...
Rhubarb Posted September 9, 2018 Share Posted September 9, 2018 The OP is using 1.51 - 1.52 is now available. Which are you using (and the same things that Cassie said would also apply). One thing that can cause problems is the router itself - when did you last reboot that? Link to comment Share on other sites More sharing options...
djk7643 Posted October 8, 2018 Share Posted October 8, 2018 1.51 & 1.52 not only slow my PC, but EVERY button click, highlight... anything, the program will go not responding. It's really horrible to even use. Does anyone have a fix? It's getting unusable for me. Link to comment Share on other sites More sharing options...
Rhubarb Posted October 9, 2018 Share Posted October 9, 2018 See if there is anything in this post that helps (especially setting the ports and router) Link to comment Share on other sites More sharing options...
