ouahab9 Posted May 28, 2019 Share Posted May 28, 2019 i need solution pls it won,t download anymore Link to comment Share on other sites More sharing options...
Rhubarb Posted May 28, 2019 Share Posted May 28, 2019 You might just be better asking in the utorrent forum - this is for Bitcomet LOL Link to comment Share on other sites More sharing options...
patrickhardin Posted June 10, 2019 Share Posted June 10, 2019 i am having same problem , the site says theres peers , but i cant connect to them , i am using avast vpn , and i still trying to use pirate bay for magnets , please help i just loooking for some old music . Link to comment Share on other sites More sharing options...
Rhubarb Posted June 10, 2019 Share Posted June 10, 2019 Unless you're also using utorrent, you won't have the same problem However, can you connect with the VPN off (normally a few seconds of a cobnnection won't trigger any alarms). Ifthat still fails, there's a possibility that there just aren't any seeds - I've had files sitting for ages with a lot of peers but no seeds (presumably all the others had the same amount of data that I had) Link to comment Share on other sites More sharing options...
