cns00 Posted May 8, 2020 Share Posted May 8, 2020 i am using bitcomet 1.57 on windows 10 build 1809 sometimes when i click on bitcomet in the start menu the program won't start. normally i fix such problems by going to the task manager and searching for the process name and i do end task and then i try to launch the program again. i checked the task manager. there is no bitcomet,exe process and there is just bitcomet disk booster service. i do end task for it and then i try to run bitcomet again but nothing happens. i need to log out of windows and sign back in so bitcomet works why is this happening? can i make bitcomet work without having to sign out and back in? Link to comment Share on other sites More sharing options...
Rhubarb Posted May 9, 2020 Share Posted May 9, 2020 I'd recommend a clean install - for a start, you are running a fairly old version - current version is 1.6 https://www.bitcomet.com/en/downloads Link to comment Share on other sites More sharing options...
