othman Posted May 13, 2020 Share Posted May 13, 2020 when i install the new version 1.67 my antivirus kaspersky delete please how i fix it Link to comment Share on other sites More sharing options...
Rhubarb Posted May 13, 2020 Share Posted May 13, 2020 Please read this post Link to comment Share on other sites More sharing options...
othman Posted May 14, 2020 Author Share Posted May 14, 2020 thank you sir , but impossible i turn off my A/v program. Link to comment Share on other sites More sharing options...
Rhubarb Posted May 14, 2020 Share Posted May 14, 2020 All we can do is to advise - if you can not (or will not) accept the advice, there is nothing else we can do. Your anti-virus is the problem here - it is creating a 'false positive' and therte is only one fix for that Link to comment Share on other sites More sharing options...
Simper Posted July 16, 2020 Share Posted July 16, 2020 On 5/14/2020 at 5:04 PM, Rhubarb said: All we can do is to advise - if you can not (or will not) accept the advice, there is nothing else we can do. Your anti-virus is the problem here - it is creating a 'false positive' and therte is only one fix for that https://www.virustotal.com/gui/file/6a572c08d212a46d95b2b8581939911d3e007ccfde356f5bd0e60a83592ed110/detection pls modify bitcomet.exe so that antiviruses do not alarm and delete it at any time. Eight popular antiviruses think bitcomet is a virus Link to comment Share on other sites More sharing options...
Rhubarb Posted July 19, 2020 Share Posted July 19, 2020 The problem is with the A.V program and NOT with Bit Comet. They are reacting to a threat that doesn't exist. PLEASE read the forum post on that issue Link to comment Share on other sites More sharing options...
Simper Posted July 19, 2020 Share Posted July 19, 2020 Ok. Have you watched the link? Microsoft's built-in Windows antivirus removes your program from any OS version. Not to mention the top antiviruses that millions of users have. Bitcomet is removed not only during installation but also at any startup. Contact all antivirus vendors and convince them to exclude bitcomet from the database. So far, bitcomet is to be removed. Link to comment Share on other sites More sharing options...
Rhubarb Posted July 19, 2020 Share Posted July 19, 2020 READ THE POST!!!!! Link to comment Share on other sites More sharing options...
