joseh silva Posted June 10, 2020 Share Posted June 10, 2020 BitComet_1.67 file: C:\Program Files\BitComet\BitComet.exe file: C:\Program Files\BitComet\tools\BitCometToastsNotifier.exe file: C:\Program Files\BitComet\tools\Updater.exe file: C:\instawb\BitComet_1.67\tools\UPNP.exe file: C:\Program Files\BitComet\tools\VideoSnapshot.exe file: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BitComet (64-bit)\BitComet.lnk regkey: HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\BitComet_x64 startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BitComet (64-bit)\BitComet.lnk uninstall: HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\BitComet_x64 p.s.: by Windows Defender Security Center Tray Icon, Windows10, v.2004 Link to comment Share on other sites More sharing options...
Rhubarb Posted June 10, 2020 Share Posted June 10, 2020 Please read this post: Link to comment Share on other sites More sharing options...
Invisible Man Posted August 5, 2020 Share Posted August 5, 2020 That post is irrelevant! It is not about the installer, but after installation. Please see https://go.microsoft.com/fwlink/?linkid=142185&name=PUA:Win32/InstallCore&threatid=213927 Link to comment Share on other sites More sharing options...
Rhubarb Posted August 5, 2020 Share Posted August 5, 2020 It's completely relevant - there is NO virus, Trojan or any other nasty in Bitcomet. The ONLY time a problem is reported is when the A/V scans the installer file and finds that algorithm Link to comment Share on other sites More sharing options...
mragross Posted August 19, 2020 Share Posted August 19, 2020 Was packagin Segurazo Antivirus also a false positive? That was a literal malware. No consent option from Bitcomet either. Link to comment Share on other sites More sharing options...
Rhubarb Posted August 20, 2020 Share Posted August 20, 2020 You won't get the 'consent' until the program begins to install and your a/v is blocking that. You HAVE to disable a/v, install andd then restart thje a/v. It is NOT malware - it's an optional app but due to the a/v detecting the bundle installation, it blocks it. I repeat - there is NO malware, there is NO Trojan and therte is NO virus. The post I gave tells you what is happening and why Link to comment Share on other sites More sharing options...
cassie Posted August 24, 2020 Share Posted August 24, 2020 *topic closed* Link to comment Share on other sites More sharing options...
