abdan Posted June 10, 2020 Share Posted June 10, 2020 (edited) As BitComet was downloading a worst crash happened that caused OS failure and then was reinstalled. The BC and the downloaded is installed in other place than the OS so there's the .blc file and .torrent file intact there. So how can I resume it to have BC downloading it as normally as it was before disaster while If the BC launched it has no the DLed item in its DL list anymore? THANKS MUCH before Edited June 10, 2020 by abdan (see edit history) Link to comment Share on other sites More sharing options...
Rhubarb Posted June 11, 2020 Share Posted June 11, 2020 If you can access the hidden folder in <user name>/appdata/Roaming/Bitcomet, copy that to a thumb drive, re-install the OS and just copy it back to the same location. To get at hidden fiiles/folders, open the drive, go to 'view' and 'options' Link to comment Share on other sites More sharing options...
