Jodie Posted July 5, 2020 Share Posted July 5, 2020 TASK PROPERTIES - not working as excpected. I downloaded a torrent that had only one file im interested in downloading. The torrent itself is 95 Gigs. I only wanted 1 file inside this torrent that is only 70 Megs. When scrolling thru and selecting only that 1 torrent and clicked ok, Bitcomet ignored my wishes and set it self up to download the entire 95 gig torrent that contains over 4,500 files. After that I even tried to go into "Task Properties -> General and deselected [download all] and select the only 1 file I wanted, then clicked ok. Well, Bitcomet is ignoring and is keeping "all" files selected. This is a Major disappointment. Also, download order sucks and can't chang "Current Priority" because there is no way to select priority downloading. Pre-selecting one file out of many at the beginning of downloading a torrent use to work. Task Properties use to work, It simply don't work anymore. This has got to be fixed for me or I will have to find another torrent alternative. Which is sad cause I used bitcomet for years. Link to comment Share on other sites More sharing options...
Rhubarb Posted July 6, 2020 Share Posted July 6, 2020 If you only want one file from a torrent, highlight the torrent, right click, go to files, select each unwanted file and click 'disable'. Unfortunately, you'll have to repeat that 4,500 times Link to comment Share on other sites More sharing options...
