perfection161 Posted December 1, 2020 Share Posted December 1, 2020 I would like to understand what these notifications/tips/error are and what i can do about them...they happen when i start the portable version of BitComet 01. Disk Boost service is not running 02. IE extension is not installed correctly. Click here to fix it Thanks Link to comment Share on other sites More sharing options...
Rhubarb Posted December 2, 2020 Share Posted December 2, 2020 1: Open options > settings and search for 'diskboot' and set it to 'true' 2: Settings > Integration - set for your browser (IE, Chrome or Firefox). Make sure that tjhe correct one is enabled and any that you don't use are disabled Link to comment Share on other sites More sharing options...
