mehrdadmms Posted March 21, 2021 Share Posted March 21, 2021 I can't log in bitcomet since this morning. Is there something wrong with the database or server? Link to comment Share on other sites More sharing options...
Rhubarb Posted March 22, 2021 Share Posted March 22, 2021 It hiccups now and again - just keep retrying (the auto-retry doesn't always work) Link to comment Share on other sites More sharing options...
antodune Posted June 14, 2021 Share Posted June 14, 2021 i can't connect to my account, it's always saying server connection ( connection au serveur ) in french and it's like that for like 9 month and i always keep retrying and he never connect to the server Link to comment Share on other sites More sharing options...
Rhubarb Posted June 15, 2021 Share Posted June 15, 2021 Try a clean install (use the demo version of Revo uninstaller) after saving the Bitcomet files in appdata) and make surew that the windows firewall isn't blocking the app Link to comment Share on other sites More sharing options...
antodune Posted June 17, 2021 Share Posted June 17, 2021 it's a new installation of bitcomet with a new installation of windows too and i did deactivate the firewall, noting, still don't want to connect to the server Link to comment Share on other sites More sharing options...
Rhubarb Posted June 17, 2021 Share Posted June 17, 2021 check that your router is set to tcp/udp ports that match the computer (it's best to use a fixed IP number for this) Link to comment Share on other sites More sharing options...
