drishnavin Posted October 26, 2022 Share Posted October 26, 2022 Cannot view snapshot and comments , im using latest bitcomet 1.95 and using windows 11 , it keep saying This program cannot display the webpage. Link to comment Share on other sites More sharing options...
Rhubarb Posted October 29, 2022 Share Posted October 29, 2022 Check your firewall settings to make sure BC can open external sites. Also check that all ports are open Link to comment Share on other sites More sharing options...
bakaczo2 Posted October 29, 2022 Share Posted October 29, 2022 (edited) I found source of the problem. M$ started to walk away from IE, so i guess you already have it covered by edge like me. I tried to unistall update (from the end of october), put registry key, nothing helped. Edited October 29, 2022 by bakaczo2 (see edit history) Link to comment Share on other sites More sharing options...
TripleThreat Posted October 30, 2022 Share Posted October 30, 2022 I have the same issue with snapshots with 1.95 version. Link to comment Share on other sites More sharing options...
faky Posted November 2, 2022 Share Posted November 2, 2022 i didn't understand how to solve the problem ( This program cannot display the webpage ) my doors are open and the firewal is ok, suggestions? Link to comment Share on other sites More sharing options...
Rhubarb Posted November 2, 2022 Share Posted November 2, 2022 Check your browser settings - that's the more likely problem for web sites No problems here (using Firefox) Link to comment Share on other sites More sharing options...
xxc Posted November 3, 2022 Share Posted November 3, 2022 (edited) I have the same problem. On both Windows and MacOS, at different locations (home and office). I use multiple browsers (FireFox, Chrome, Edge). Turned off all firewall. Nothing works. I'm at Eastern US. Bitcomet version 1.95. Tried to download older version but still cannot solve the problem. Any suggestions? Is it because the servers are down or just local setting problem? Or maybe the ISP in my area are blocking the snapshot server? Thanks. Edited November 3, 2022 by xxc modify question (see edit history) Link to comment Share on other sites More sharing options...
Rhubarb Posted November 3, 2022 Share Posted November 3, 2022 Blocking? it's possible, however, did you check if there are any snapshots after download is complete? Comments only really work if people actually post them (most don't) and, if it isn't there, then you won't get it 1 Link to comment Share on other sites More sharing options...
auset Posted November 3, 2022 Share Posted November 3, 2022 on torrent collection there are some torrents with comments or snapshots or both recently(for quite a long time now) I cannot view both of them with the same issue i have tried various means, turning off firewall, updating the client, changing internet options etc, none seemed to work, I thought it is the problem with the server as the server that hosts the comment and snapshot may be down, but now it doesn't seem to be the issue(maybe it is blocked by the internet provider but I don't know the host for comments and snapshots so I don't know) I am using windows10, I am able to navigate to different websites using IE that's built in bitcomet, but This program cannot display the webpage still occurs when attempting to view comments and snapshots 1 Link to comment Share on other sites More sharing options...
Canteentent Posted November 4, 2022 Share Posted November 4, 2022 I have this same issue... We're talking about the Snapshot tab of a downloading or loaded torrent (Both in the All Downloads area and Torrent Collection area). Rhubarb references the usage of Firefox, but i'm not sure how that's relevant because i'm not aware of how we can switch which browser is used to display the snapshots. (i'm assuming you're talking about changing the browser used to embed within that window). So, is there a way to choose which embedded browser is used to display those snapshots? Otherwise, i'm not sure why Browser makes an issue. Alternatively, is there a way to extract the URL that's being referenced when it looks for the snapshot page, such that we can try to see if we can get to the page outside of BitComet? 1 Link to comment Share on other sites More sharing options...
faky Posted November 4, 2022 Share Posted November 4, 2022 I tried to install firefox and make it default, uninstalled bitcomet and reinstalled off and on the pc again, but nothing always gives me the same error, and I can't see the snapshots, or tried among various settings if I had changed something, but it seems everything ok, I don't know what to do anymore. 1 Link to comment Share on other sites More sharing options...
donut Posted November 11, 2022 Share Posted November 11, 2022 I have the same issue with any versions of Bitcomet (MacOS version) not only the latest version. It did work before, but now every time i open the "Comments" or "Snapshots" tab, it shows only This program cannot display the webpage. 1 Link to comment Share on other sites More sharing options...
triggerre Posted November 12, 2022 Share Posted November 12, 2022 +1 17 hours ago, donut said: I have the same issue with any versions of Bitcomet (MacOS version) not only the latest version. It did work before, but now every time i open the "Comments" or "Snapshots" tab, it shows only This program cannot display the webpage. 1 Link to comment Share on other sites More sharing options...
xxc Posted November 12, 2022 Share Posted November 12, 2022 On 11/3/2022 at 12:06 AM, xxc said: I have the same problem. On both Windows and MacOS, at different locations (home and office). I use multiple browsers (FireFox, Chrome, Edge). Turned off all firewall. Nothing works. I'm at Eastern US. Bitcomet version 1.95. Tried to download older version but still cannot solve the problem. Any suggestions? Is it because the servers are down or just local setting problem? Or maybe the ISP in my area are blocking the snapshot server? Thanks. Update: I tried using VPN with Bitcomet to test if it is the ISP issue. Turns out it maybe not. I tried to VPN to Ireland, Brazil, Vietnam, South Korea, Austrilia... nothing works. It is highly possible that this is a Bitcomet issue rather than the ISP. Could anyone get the comment and snapshot working currently? Please share. Link to comment Share on other sites More sharing options...
xxc Posted November 13, 2022 Share Posted November 13, 2022 6 hours ago, xxc said: Update: I tried using VPN with Bitcomet to test if it is the ISP issue. Turns out it maybe not. I tried to VPN to Ireland, Brazil, Vietnam, South Korea, Austrilia... nothing works. It is highly possible that this is a Bitcomet issue rather than the ISP. Could anyone get the comment and snapshot working currently? Please share. Update 2: OK Get reports from multiple regions saying problems with comment and snapshot for a long period. The comment server is https://www.xytalk.net The snapshot server is https://image.fileshot.net Both are currently down (ping is OK but cannot be accessed by any web browser). Let's hope it can be fixed soon. 1 Link to comment Share on other sites More sharing options...
faky Posted November 17, 2022 Share Posted November 17, 2022 miracolo, l'istantanea funziona, o hai fatto qualcosa per mordere cometa, o dopo innumerevoli test ho trovato il browser predefinito giusto per bitcomet, io uso edge, dichiaro all'inizio non ha funzionato per me, ma ora sì, non provo più ora, lascerò tutto così, speriamo per il meglio. Link to comment Share on other sites More sharing options...
donut Posted November 18, 2022 Share Posted November 18, 2022 I didn't change any settings. Now it works, server is up again. Thanks to anyone who fixed it. Cheers! Link to comment Share on other sites More sharing options...
triggerre Posted November 18, 2022 Share Posted November 18, 2022 14 minutes ago, donut said: I didn't change any settings. Now it works, server is up again. Thanks to anyone who fixed it. Cheers! yup same here. thanks! Link to comment Share on other sites More sharing options...
auset Posted November 18, 2022 Share Posted November 18, 2022 yep....it's seems that the server was just down for a really... long time🤣 Link to comment Share on other sites More sharing options...
SlvrSrfr Posted February 10, 2023 Share Posted February 10, 2023 (edited) any word on this, it all continues to be unavailable? Can that^ server get restarted plez? Edited February 10, 2023 by SlvrSrfr (see edit history) Link to comment Share on other sites More sharing options...
SlvrSrfr Posted February 10, 2023 Share Posted February 10, 2023 (edited) On 11/12/2022 at 9:27 PM, xxc said: Update 2: OK Get reports from multiple regions saying problems with comment and snapshot for a long period. The comment server is https://www.xytalk.net The snapshot server is https://image.fileshot.net Both are currently down (ping is OK but cannot be accessed by any web browser). Let's hope it can be fixed soon. yup both, 404 error Edited February 10, 2023 by SlvrSrfr (see edit history) 1 Link to comment Share on other sites More sharing options...
donut Posted March 2, 2023 Share Posted March 2, 2023 The Snapshots is not working.. again. Now it is showing this error message Please upgrade to latest version. (not released yet) Link to comment Share on other sites More sharing options...
Rhubarb Posted March 3, 2023 Share Posted March 3, 2023 Which version are you using (current is 1.98)? The reason for asking is that the versions on sourceforge, etc are at least two behind the official website one Link to comment Share on other sites More sharing options...
donut Posted March 4, 2023 Share Posted March 4, 2023 19 hours ago, Rhubarb said: Which version are you using (current is 1.98)? The reason for asking is that the versions on sourceforge, etc are at least two behind the official website one Yes, I am using version 1.98 Link to comment Share on other sites More sharing options...
SlvrSrfr Posted March 6, 2023 Share Posted March 6, 2023 (edited) all software is current, and still no response from server. Edited March 6, 2023 by SlvrSrfr (see edit history) Link to comment Share on other sites More sharing options...
