TripleThreat Posted October 30, 2022 Share Posted October 30, 2022 Beside the snapshot problem, there are two issues I found particular with the new v1.95: 1) Failure to transfer torrent task folder to a new location. I have to manually transfer the folder to the location I want in Windows Files Explorer and point the new location within the torrent task inside BitComet. 2) Opening .torrent files don't automatically open up a new task with BitComet. I have manually open the .torrent files with BitComet to add new tasks. Link to comment Share on other sites More sharing options...
TripleThreat Posted November 1, 2022 Author Share Posted November 1, 2022 I should rewrite Point 2 more clearly: 2) Double click the .torrent files in Windows Files Explorer don't automatically popup a new task window of BitComet. I have to get inside BitComet to open the .torrent files manually then a new task window would popup. Link to comment Share on other sites More sharing options...
Rhubarb Posted November 2, 2022 Share Posted November 2, 2022 Try right click and 'open with'. You should be able to associate .torrent files with bitcomet in the browser Link to comment Share on other sites More sharing options...
