Save & Export/Import ability for "Options" setting page.
Pregi
Hi
It would be so helpful if you could have the option to save and export all the settings you made in the "OPTIONS" section so when we upgrade or use Bitcomet on another computer or if we need to setup Bitcomet on a friends computer after convincing them to use Bitcomet instead, we can just import the saved settings and all is done immediately.
  • Like 1
