amarsi Posted March 22, 2023 Share Posted March 22, 2023 I'm currently using BitComet 1.98 on Windows 10 and I'm fine with it. But I have a problem. In directory C:\Users\...\AppData\Roaming\BitComet\torrent_cache\... 730,269 files have accumulated, over 2 years (32GB). In addition to the important occupation of space, I have the impression that this slows down some procedures. I would like to know if it is possible to delete them totally or only the most recent ones and if there is a procedure to do it or if I can do it manually. Thanks for the attention. Link to comment Share on other sites More sharing options...
RocZi Posted February 11, 2024 Share Posted February 11, 2024 (edited) I have the same issue. its 73 GB for me now after 3 years+. I think it is used to check if we have downloaded the exact same torrent before. i saved all torrents to its respective folder, so i think its safe to delete them as they are all hash numbers, impossible to know which is what. Edited February 11, 2024 by RocZi typo (see edit history) Link to comment Share on other sites More sharing options...
