Can not log in. At Bit Comet program!? Please Help...
ingothe
Hello Ma FrienZzzzz.....
Start the Bit Comet download program. It constantly says below:
'Connect to server' and this orange graphic.
Which I've been seeing for years now!? But I have to take care of it now. I've tried everything that can be done....reinstalling etc.....everything!!!
Go crazy. Please help me....
Greetings Denn1Ze
  • 1 month later...
Yes, thanks for the tip, my friend! I've tried everything and I've been using computers for about 40 years...
Even the entire firewall etc. was turned off...no success. Unfortunately...I guess I'll have to keep trying until it works.
Thanks again
You may have a corrupted installation so try this: Uninstall BC using Revo Uninstaller (back up he settings in AppData if you have a lot of files in use) and then clean the drive using Puran Utilities and then re-install
Am 17.12.2023 um 19:38 Uhr sagte Rhubarb:
Alright thanks. I just got 'Revo Uninstaller Pro'
Publication year/date: 12.2023
Version: 5.2.2
Developer: VS Revo Group
Developer website: VS Revo Group pulled and 'Puran Utilities'.
Install both and will try it out in a few hours. Hopefully this works and thank you again BrO
Gut, danke. Ich habe gerade „Revo Uninstaller Pro“ thumb-9fa43ab7d2f377b31f46cfb598fc1b68.png.5e9b0488533f2725e7be64da0921341e.png
Veröffentlichungsjahr/-datum: 12.2023
Version: 5.2.2
Entwickler: VS Revo Group
Entwickler-Website: VS Revo Group gezogen und „Puran Utilities“.
Installieren Sie beide und probieren Sie es in ein paar Stunden aus. Hoffentlich funktioniert das und nochmals vielen Dank, BrO
By the way, MERRY CHRISTMAS FROM GERMANY
  • 2 months later...
