running a downloaded programme
With the little amount of info you gave all I can do is point you here
http://forums.bitcomet.com/index.php?showtopic=204
tks for that
I tried following this page and turned all the icons into winrar icons. I then got alcohol120 but it couldnt recognize anything.
any ideas?
:mellow: what is the extension of the file? :mellow:
the_name_of_the_program.???
what are the last 3 letters after the dot? :mellow:
the name of the program is signlab it came on 2 cds. the last icon on each has an extension s-csv141.sfv
