Crash621 Posted August 3, 2006 Share Posted August 3, 2006 I have a concern about my download/upload speed. I have version DSL and I am only downloading around 5-10kb\s I thought that 25kb\s which was the fastest i have ever reached was amazingly fast when i hit it But then i went to the forms and saw that that is very very low i see people with 100 200 300 even 800 Download speed, and a very high upload speed. I was wondering if anyone has any ideas how to fix this problem thanks also my upload speed is at 94 while download is only 5-10 Link to comment Share on other sites More sharing options...
dimchopicha2003 Posted August 3, 2006 Share Posted August 3, 2006 read all the FAQ's and find the settings for BC. you should be ok then. how much is your download speed depends from you bandwidth. From this you told I supposed you have 1Mbit DSL this means your max speed download or upload could be 128KB/s but this is only if your connection is 1Mbit - you should check how exactly is your bandwidth. you at least should have download speed = upload speed. But remember no matter how fast connection you have you are always dependent on the peers and seeders upload speed. Link to comment Share on other sites More sharing options...
