shmoos5 Posted August 3, 2006 Share Posted August 3, 2006 <_< Ok I have a problem...I downloaded the Blue Collar comedy Tour ...from mininova....and when I went to play it, I had to turn my volume on my speakers as high as they would go, just to hear it a little bit...so I burned it, and thought maybe I could rectify it using my tv speakers.....but it is still too low...is there a way I can change this, or should i just go and get another copy??? Link to comment Share on other sites More sharing options...
kluelos Posted August 3, 2006 Share Posted August 3, 2006 Check the site that originated the torrent, to see if there are any comments or followups. If others have had the same problem, it may have been fixed and re-released. Generally, if there are problems with the video or audio, burning to disk isn't going to fix them. Link to comment Share on other sites More sharing options...
dimchopicha2003 Posted August 3, 2006 Share Posted August 3, 2006 you have 2 choices 1.to edit the movie and increase the volume level (forget about it) - wasting of time. 2.to go to your audio driver settings in control panel. if you have a good audio driver you will have many setting to adjust there, so increase to max all equalizer settings, master volume, bass, treble, mid.... what is your mainboard, chipset? Link to comment Share on other sites More sharing options...
