help!
m not getting good speed in bit commet though the bit commet bar shows dowloading speeds of around 25 kbps but the actual speed shown on the client is only 5kbps!
where does this remaining speed goes?the previous version used to give me better downloading speed!
what should be done to inprove my downloading speed?
Make sure if you have a router that you open Bitcomets port in the router (portforwarding)
Make sure to set your upload cap to ~80%
Read through the settings guide in my sig for help with these
Maybe its just the torrents your running now that are the problem (not enough seeds/peers)
