stinky Posted August 9, 2006 Share Posted August 9, 2006 Hi you all, I just joined the forum and went through it without finding an answer to my question, so I have started a torrent to download a movie from a Chinese torrent site. What can I do to view the file names in Chinese. They are all scrambled in gibblish. And how do I open a rmvb.bc movie file. Thanks. By the way I have NJ star viewer and WP. joy to all ;) Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 9, 2006 Share Posted August 9, 2006 rmvb is a real media file. Get the Real Alternative codec. http://www.free-codecs.com/download/Real_Alternative.htm Link to comment Share on other sites More sharing options...
dimchopicha2003 Posted August 9, 2006 Share Posted August 9, 2006 to enable support for chinies go to: start menu->settings->control panel->regional and language options->languages->check install files for east asian languages. Link to comment Share on other sites More sharing options...
stinky Posted August 11, 2006 Author Share Posted August 11, 2006 to enable support for chinies go to: start menu->settings->control panel->regional and language options->languages->check install files for east asian languages. OK I went to start menu>.......languages... the install files for east asian languages is already checked. May be a Windows XP disk has to be inserted and the languages has to be chosen to be installed. So I tried unchecked the east asian languages box. It warned me the asian language files will be uninstalled which I don't want so I closed the dialog box. I checked the box again and hit OK. The box is checked but do I need to restart to see its effect or something. By the way bitcomet rocks I got 6 movies files completed within hours :) Thanks joy to all Link to comment Share on other sites More sharing options...
dimchopicha2003 Posted August 11, 2006 Share Posted August 11, 2006 (edited) i cant remember exactly how i did it it was long ago. normally this should be enough to be able to recognize chinese symbols. search google for read chinese windows. link Edited August 11, 2006 by dimchopicha2003 (see edit history) Link to comment Share on other sites More sharing options...
